P
pacokia
my heating is staying on cold everything else is working but when you turn it to hot it is cold can anyone help thanks
thanks forgot to say aswell the ac light is staying on red
As above, the heater shut off valve. Sod to get to under the brake master cylinder.
Give it a tap with the wheelbrace, I did on mine, worked a treat..
See http://forums.mercedesclub.org.uk/showthread.php?t=54999
I've had to bash mine twice this year.......
We do get outsiders reading these post,,could not you describe the fault like,,the Duo valve needs a little stimulation at times
