heavy power steering at low speed. c class c200
Discussion in 'Suspension, Steering & Brakes' started by briza c class c200 cdi 55, Dec 28, 2009.
  1. briza c class c200 cdi 55
    briza c class c200 cdi 55 Member
    10
    Dec 28, 2009
    Hi i have a c200 cdi 55 plate. the steering is heavy at low speed and gets more heavy when parking. i have had it to the workshop they told me this is normal. has anyone had the same problems as this is not normal its a bit of a pain. any info would be good thanks
  2. oigle
    oigle Senior Member
    3,044
    357
    Mar 15, 2005
    Your Mercedes:
    Currently 2003 ML270. 2012 Nissan Maxima 250SL.
    If you don't have any mechanical issues, as your workshop suggests, my only suggestion is to over inflate your front tyres by 3 or 4 pounds pressure. This will help quite a bit. I presume you have standard size tyres fitted? Wider tyres do get heavier in the steering at low speeds.
  3. Xtractorfan
    Xtractorfan Senior Member
    6,084
    155
    Nov 16, 2007
    Your Mercedes:
    S class
    When the dealers tell you that this is normal for that model of car .. always ask for a test drive in anoither similar car .. or go along and just test drive a few then compare notes..
  4. television
    television Always remembered RIP
    164,074
    310
    Your Mercedes:
    You could have the variable steering and this can go wrong making parking heavy,,this has been up before, so do ask the dealer to check on this point
  5. OP
    10
    Dec 28, 2009
    heavy steering c200
    Hi thanks for your reply. i have already tried the tyre presure and the power steering flude is ok. some say its a weak power steering pump or faulty sensor. is this a common fault? i have driven a 2002 c class older then mine and the steering feels alot better its like driving a different merc. when driving my 2005 it seems harder more effert is needed. and when turning corners i have to help the weel straighten up this is not normal for any car let alone a merc. any ideas or has any other mercedes drivers had the same problems? thanks
  6. television
    164,074
    310
    Your Mercedes:
    With the VIN number i could check to see if the car does have the speed sensitive steering and the car should be put on STAR to check if you have fault codes C1014, C1501 or C16EF
  7. OP
    10
    Dec 28, 2009
    Yes please where will i find the vin number?
  8. television
    164,074
    310
    Your Mercedes:
    In the front of the screen, bottom passenger side or on the V5 log book starting WDB203
    Do not do it this evening as I am going to bed now
  9. OP
    10
    Dec 28, 2009
    what do you mean by a star is it a computer?
  10. television
    164,074
    310
    Your Mercedes:
    STAR is the MB test set used to program the cars and read off fault codes when something has failed, all the indies and dealers have one,,and even i have one
  11. OP
    10
    Dec 28, 2009
    Hi mate my vin number is wdc2030072r207862. i have also booked the car into an Independent Mercedes-Benz Car Specialist. they only charge £50 for a star and mercedes whant £118 what a saving.
  12. OP
    10
    Dec 28, 2009
    Hi mate my vin number is WDC2030072R207862. I have booked my car into an Independent Mercedes-Benz Car Specialist for a STAR they only charge £50 mercedes want £118 what a saving.
  13. television
    164,074
    310
    Your Mercedes:
    I have looked at the data card,,but I cannot see it listed,,and it may be standard,,your man will know by the feel of the car and any fault codes
  14. malcolm210
    malcolm210 Senior Member
    4,290
    1,196
    Aug 21, 2005
    Food for thought!
    I've just changed my front tyres from NCT5 to Pirelli P6000s (NCTs managed 35K). I have noticed one significant difference since the change in that the steering has become very much lighter. All that has been done is the tyre change, no tracking etc. It would indicate that type of tyre and tread pattern also influence the feel at the wheel.
    Hope this helps!
  15. OP
    10
    Dec 28, 2009
    thanks mate ill wait to see what the star comes up with. if nothing i will change the tyres. i will keep you updated.
Share This Page
