Hello everyone, my roof problem ,i need help
eggy91sl500
91sl500
91so 500, I have cleared all the faults, but when I try to operate the roof the Windows drop as normal,but nothing else happens, the pump is working.
I had to drop the roll bar manually.
Roll bar not moving either.
Any help appreciated.
Wearsafoxhat
Sunny Hampshire by the sea
E63 :S213, SL500 :R129 , V220
Is there oil in the pump.. have you reset the windows and roll bar…is the battery fully charged or engine running… but could be one of numerous switches playing up.
Perhaps raise and lower the roof manually to work the switches.
E
eggy91sl500
91sl500
Thanks for your reply, yes plenty of oil in pump, done the Windows,engine both on and off,
I done the flash codes.
Port 10 for the soft top is showing code 20 + 24
Port 7 roll bar is showing 1 flash ,which is clear of faults.
I thumped the floor under the rear seats and the roll bar deployed .but won't operate the pump.
E
eggy91sl500
91sl500
Thanks for the info, I will have to keep trying things, the car was last on the road in 2009, so possible that all the sensors are sticky ,.
Spray them all with electrical cleaner .
E
eggy91sl500
91sl500
Will do eighty ,when I get a chance ,due to work
