Help!BAS warning light and engine cut out SLK 200
tanyad
Surrey
slk/2001/200tp
Hello
I've recently bought a 2001 reg SLK 200 Kompressor. The BAS ESP warning light comes on intermittently and today the engine suddenly cut out at a junction. Luckily, the car restarted again at the first try. Mileage is just over 32K.
I've searched through the forums and have seen a few posts with similar problems but call me a technobimbo :Oops: the solutions seem a bit too technical for me...
a) is this a serious problem? (the engine cutting out, not my technical lack of knowledge)
b) can anyone recommend a good independent garage/mechanic near weybridge where I can get the fault fixed without being ripped off
Many thanks in advance for your help
Tanya
T
tanyad
Surrey
slk/2001/200tp
Reading might be a bit too far, specially if the engine keeps cutting out! could take me days...
A
andy@pcd-ltd
What about a mobile mechanic with a star machine.........................
T
tanyad
Surrey
slk/2001/200tp
Thanks Alf230.
Is that a major job or easy enough to sort out?
I am pleased tat you have posted I was just thinking of you and if it was too far :D:D
A
andy@pcd-ltd
No its not too far i was in rochester in kent today so weybridge is just round the corner
T
tanyad
Surrey
slk/2001/200tp
Thanks Willow!
Are you going to be 'around the corner' soon? :)
Miffy
Bromley, London
CLK 320 CAB Elegance C208
if its the CPS, would it have restarted straight away with no cool down period?
What would? Normally a CKS fault won't allow instant restart.
Of coarse it will not
Read it how you want to, but I was saying that it would not have started straight away if it was that
dieselman
A diesel
No problem, it was just on first read it didn't read as if you thought that to be the case.
T
tanyad
Surrey
slk/2001/200tp
so, I take it that it is probably not the CPS/CKS? Is that the same thing as the crank sensor? (I did warn you that I'm a technobimbo...)
Thanks for taking time to reply - much appreciated by a newbie
It was how it was all worded, forgive me through being ratty this evening
Yes that would be the same thing,you would have had to wait for quite a time if it was that.
How many times did it stop
T
tanyad
Surrey
slk/2001/200tp
  • #18
Just the once. The BAS warning light came on a couple of miles later.
Miffy
Bromley, London
well it sounds like willow could soon be on the case so we will soon know whats broke
There is not that much to the BAS but STAR will tell you what that fault is.
The stopping is too hard at this stage
