dangermose240
- Nov 7, 2007
Help I have a C240 that wont crank, When I insert the key the dask lights up and all looks ok but when I turn the key nothing.
I have a Star system and have tested the keys and then the EIS and the keys are fine and I get the start signal from the EIS
so its not that.
I jumped the purple wire in the front SAM to the +terminal and the starter kicks in and cranks so I dont think its a starter problem.
I also swapped out the starter relay for the Horn realy and this didnt do anything.
I checked all the fuses and nothing is blow.
I scanned the gearbox and the gear selection seems correct and shows no errors.
Battry is old but showing 12.4v on Star.
I cant test any of the relays as you need a socket box add on for the star that I havent got.
Could this be a dodgy ME-SFI, Is this the main computer? If I get a second hand one can I plug and play or does this also hold the key
information.
Please excuse my lack of knoledge if I think I have all the names correct, Am a bit lost on what to try next.
Many Thanks
Chris
so its not that.
information.
Many Thanks
Chris
