I have a 1984 280 CE (W123 series) and would appreciate any advice on how to open the bonnet which has stuck.
The other day when I opened the bonnet the plastic safety catch broke (the one that protrudes through the grill), as a quick fix I attached a cable tie to the release lever inside the bonnet.
I have now tried to open the bonnet and it will not budge.
The cable is fine as is the release catch, I can hear them operate and the bonnet move very slightly to one side but no amount of pulling will release the bonnet from the catch.
As I can no longer see the cable tie I suspect when I last closed the bonnet the cable tie got caught and is trapped in the bonnet lock and is now jamming the bonnet.
So the million dollar question is what do I do now?
I have had one person pull the release catch while two others managed to get their fingers under the edge of the bonnet to pull it up but so far no success and my fear is that the bonnet will bend if pulled too hard.
I assume that I cannot take the grill off without opening the bonnet and I also assume that access from underneath is very limited so I am now wondering if the only option would be to break a couple of the plastic vanes so there is enough space to inset a lever.
Therefore with regards to the lever idea, is there a plate or section on the bonnet near the lock that I can lever against without damaging the surface of the bonnet?
My theory is that if the cable tie has jammed the bonnet then sufficient force will remove it but of course I don't want to damage the bonnet in the process.
To make the problem worse the battery is flat so I can’t take the car to a garage.
Help.
Help.
