Help CL500 2001 fault
Daftpunk2005
New Registration
CL500 2001
HI Guys
I have a 2001 CL500 with an ABS light I can get rid of. The scan shows error code C1011 Traction System Hydraulic unit - A7/3. I have checked fuses, replaced the pump which has not solved the problem. I have checked the power to the motor and the power to the loom (socket) and I have no power.
Also the radiator fan is running permanently which i think is another problem but maybe not related.
Does anyone have a wiring diagram and fuse and relay diagram or have access to the workshop manual for the car ?
Best
Daftpunk
bembo449
gainsborough , lincolnshire
Possible SAM unit problem, have you checked anything else for a fault pal and i mean anything , like the horn or wipers ???
When you say replaced the pump I assume you mean ABS pump?
Also be aware there is more than one fuse box.
Fan running all the time can be low A/C gas - a regas usually fixes it.
