help diagnostic plug faulty
steve1
just brought a diagnostic kit that is obd 2 and only merc s320 on a 01 plate interface when plugging unit in there is no communication, think the wiring could faulty has anyone had this issue
steve
95 times out of 100 its the reader that cant communicate with the car, you are using the 16 pin socket under the dash
jibcl500
Cambridgeshire
CL500,ML55,SLK280
You need to give more info on the diags system you have as the cheap diags on ebay dont have all the K lines connected so they wont talk, also Ive found some Mercedes to have had the fuse removed so diags dont communicate, only assume some dealers do it or indies so the car comes back to them.
jib
steve1
steve1
hi,
yes tried the 16 pin socket had no luck, and the diag is a PANASONIC LAPTOP + CAR DIAGNOSTIC CODE READER OBD OBDIIe
steve
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Is the ignition ON al dash lights etc? Where did you buy this product from?
Is the software Carsoft and does it come with a multplexor? Post pic if possible of equipment.
jib
steve1
steve1
belive it or not it was a fuse, the reason i got the diag was the aircon light wont turn of nor can i shut the outside vents and its showing no fault codes, just my luck
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Take the 38 pin to 9 pin D connector remove the screws from the 38 pin plug and see how many wires there are inside, if 3, one yellow, one black , one grey then only one K line is connected which means this system wont read other systems on the car. Using the 16 pin socket wont change anything either. Never seen this system before and Ive spent lots trying and spent many many hours researching. Sorry but I think youve bought a pup.
jib
steve1
steve1
I dont seem to have the 38 pin conecter, can get data but all seems clear even though I have the above issues
I have read the spec and this unit will not cover the car, only the engine is covered
steve1
steve1
But I have been into the airmatic system and abs
Yes correct,,that test equipment will keep you on the road for fault codes for items involved in the running gear.
The air con comes under body adaptations and a MB dedicated program is needed to go into that part of the car.
Cars have another CAN BUS for things like seats mirrors aircon etc.
Some programs like Carsoft 7.4 and the X431 will do these programs
steve1
steve1
sounds like you know your stuff, thanks for all the info it has been usefull.
