- Dec 8, 2009
- Location
- Bristol/Somerset
- Website
- www.avantgarde-automotive.co.uk
- E300 Coupe AMG Line PP/NE, SLR McLaren Roadster, SL55 & C32AMG
The injectors will come out, your garage just dont have the right tools/knowledge to remove them, I have removed injectors where the carbonisation is so bad you cant see the leak off pipes.
As regards the other fault of oil leaking out the dipstick, I would check the breather but I dont think even if that was blocked solid it would cause that fault. I would suggest it has major crankcase compression.
I would remove the injectors and do a compression tesf the engine. It could be something else.t before doing anything else like writing of
