Help fit New Discs and Pads Lincoln? W213 E class
Discussion in 'Suspension, Steering & Brakes' started by Janchee, Feb 25, 2020.
Tags:
  1. OP
    Janchee
    Janchee Senior Member
    193
    105
    Jan 23, 2020
    Lincoln, UK
    Your Mercedes:
    W213/2016/220D 190
    You’re right - I should be able to do it myself however, I haven’t got the space or confidence to do it on such an expensive car.
    I’m highly skilled in another area so I’ll just use the money I make on that to pay a local garage to do a good job It’s one of my goals to own a garage big enough with a ramp!! :cool:
  2. bembo449
    bembo449 Senior Member
    4,890
    1,896
    Jan 2, 2012
    gainsborough , lincolnshire
    Your Mercedes:
    Mercedes Cl500, land rover discovery 3 , insignia vxr , shitron dispatch
    you only have to ask pal , i run my buisness doing all this sort of thing
    simon
    Wighty and Janchee like this.
  3. fabes
    fabes Senior Member
    443
    188
    Nov 14, 2015
    Your Mercedes:
    E 350CGI Coupe
    Your damaged alloy can then be sold or repaired /sold to recoup some costs (or of course, keep it for next time.....)
    Janchee and Wighty like this.
  4. OP
    Janchee
    193
    105
    Jan 23, 2020
    Lincoln, UK
    Your Mercedes:
    W213/2016/220D 190
    That’s the ticket!
  5. MarinB17
    MarinB17 Member
    18
    17
    Jan 21, 2020
    Your Mercedes:
    C350 Petrol MY12 Estate
    if you are not in a rush try autodoc.co.uk for discs and pads, textar are OE mfr
    Any local garage will do it for you, bread and butter job
    Wighty likes this.
  6. bembo449
    4,890
    1,896
    Jan 2, 2012
    Your Mercedes:
    I agree , brembo arent all that and im the local garage he can use
  7. OP
    Janchee
    193
    105
    Jan 23, 2020
    Lincoln, UK
    Your Mercedes:
    W213/2016/220D 190
    Thanks all. Would be interested to know what manufacturer forum members recommend regarding brake pads and discs?
    I've used Brembo before and they were pretty good quality. ECP also has a 50% sale right now making each disc only £60.
    Phoned Mercedes Parts at the local dealer. Front Discs are 71.54 + VAT, Front Pads are 67.33 + VAT. Not too bad tbf. I mentioned the ECP deal and the guy on the phone said he could possibly do them at trade price (-10%)
  8. OP
    Janchee
    193
    105
    Jan 23, 2020
    Lincoln, UK
    Your Mercedes:
    W213/2016/220D 190
    Would they use just one supplier?
  9. V6Matty
    V6Matty Senior Member
    6,510
    1,321
    Aug 1, 2012
    Newark, Notts
    Your Mercedes:
    S212/10/E350(His) W169/2005/A180 (Hers)
    Previous owner fitted Brembo disks and pads to my 212, they squeaked at low speed and have also developed a vibration under braking,
  10. bembo449
    4,890
    1,896
    Jan 2, 2012
    Your Mercedes:
    They are standard on my VXR insignia , pile of crap , overheat too easy and rattle like the cars going to fall apart
  11. V6Matty
    6,510
    1,321
    Aug 1, 2012
    Newark, Notts
    Your Mercedes:
    Not a fan personally,
    Simon, as a side note the vibration does match that of Jimbo’s you’d be welcome to have a test if my car and see what you think, may help both of us out as to a root cause to these juddering disks.
    sorry for the hijack Jan
    Janchee likes this.
  12. bembo449
    4,890
    1,896
    Jan 2, 2012
    Your Mercedes:
    yeah pal , no problem but I really don't rate Brembo at all Matty
  13. OP
    Janchee
    193
    105
    Jan 23, 2020
    Lincoln, UK
    Your Mercedes:
    W213/2016/220D 190
    What pads/disc manufacturer do forum members recommend??
  14. JBell
    JBell Senior Member
    11,613
    3,556
    Dec 9, 2011
    Torquey
    Your Mercedes:
    C350 CDi Estate (GAD Edition)
    I use Pagid or Brembo, never had an issue and no squeaking
  15. malcolm210
    malcolm210 Senior Member
    4,089
    994
    Aug 21, 2005
    MB at the price you quoted above, my feeling is that even OEM don’t like a hard life I think nowadays you need to pay top dollar if you use the brakes hard, my son’s W213 should never have needed discs at <20k miles but they were noisy which led me to believe the car had been driven quite hard, he on the other hand is light on brakes and no probs 30k miles on with MB discs and pads
    Janchee likes this.
  16. V6Matty
    6,510
    1,321
    Aug 1, 2012
    Newark, Notts
    Your Mercedes:
    I’d go pagid, or textar
  17. OP
    Janchee
    193
    105
    Jan 23, 2020
    Lincoln, UK
    Your Mercedes:
    W213/2016/220D 190
    MB will use multiple suppliers in their supply chain for discs and pads. Maybe he got a good one
    Not heard good things about Pagid on other forums
  18. malcolm210
    4,089
    994
    Aug 21, 2005
    The front discs on my 435i are two piece and the replacement costs reflect that not that I’m likely to stopping from >100 mph, some do though especially in Germany
  19. mercmancdi
    mercmancdi Senior Member
    3,254
    698
    Dec 6, 2011
    templepatrick - co antrim
    Your Mercedes:
    2009 E250 cdi 08 cls320 cdi ,2007 e280 cdi '2005 E 280 CDI ,VW TOUAREG ,JAGUAR S AND xTO NAME A FEW
    You know if a disc is badly warped and you jack car up and wheel off and turn the disc you will see the twist as it turns ,the disc where it’s warped will come in close to the brake pad and out again as you turn it. If you do this you will know which is warped . No point in spending money replacing good disc.
  20. JBell
    JBell Senior Member
    11,613
    3,556
    Dec 9, 2011
    Torquey
    Your Mercedes:
    Pagid are there main supplier, part of the "Friction Products" portfolio. I have used them on 4 Mercs, 2 audi's and 3 VW's with no problems at all, they just need to be fitted properly
Share This Page
