Help, heater either hot or cold!! W203
philiggy
Harrogate
c200 CDI 2006
Hi all
havent been on here for ages.
Just bought a 2006 c200CDI
The heater is eithe red hot or cold....its terrible, cant find antthing on it and its making car unusable
Cheers
Phil
AMGeed
Poole, Dorset
S204 C180K
Get your duo valve (heater control valve) checked.
I had similar symptoms and mine looked like this on removal
philiggy
philiggy
Harrogate
c200 CDI 2006
Its all fine just had thermostat replaced,,,,where is duo valve situated?
AMGeed
Poole, Dorset
S204 C180K
Should be under the master cylinder on the drivers side bulkhead. The part isn't expensive £30 odd but its an awkward job to do.
BTW, this is only an opinion and please confirm with an indy/your garage before deciding to replace this valve.
philiggy
philiggy
Harrogate
c200 CDI 2006
apparently mine doesnt have a duo valve!
philiggy
philiggy
Harrogate
c200 CDI 2006
AMGeed
Poole, Dorset
S204 C180K
OK.........I thought all W203's had them??
Oh well, back to the drawing board:(
andy.alias
2005 C220 CDI Avantgarde SE Auto
Hi Philiggy, did you ever fix this?
Yes, no duovalve on the W203's. Heat/cooling is controlled by flaps.
You can try normalising the flaps by holding Windscreen defrost and recirc buttons until the lights flash.
andy.alias
Tried that, made no difference, I have read that it could be the sensor, but I’m not sure where it is, some say the roof light cluster and some say the controll dials..
You need to plug it into diagnostics and compare the values from both.
Oldspanners
Normandy
C CLASS 2004 C180
Do you have any clicking noises coming from around the heater controls on switching the ignition on or off.
I had this problem and it turned out to be a heater flap control motor but can also be a cracked plastic operating arm.
andy.alias
No ticking noises, I might try a punt on a new light fitting, only a tenner on eBay.
