Help,, horn not working
carnutrolo
north somerset
:(Hi,, can someone please help!!. cars due for a mot, but the horn dosnt work.
to be honest it hasnt worked since ive owned the car. there is no power on fuse 37, ive had the air bag off the steering wheel, and both horn wires are conected. both horns have wires going to them,, so any sugestions are very welcome.
thanks for any help;; andy
its a 2002 ml500
Have you tried putting a 12 volt feed to them, that would tell you if its the horns or not!
C
carnutrolo
north somerset
hi, do you mean 12v supply to the horn terminal, ive checked both horns and theres no supply?. can i put a 12v supply to the fuse?. or would that backfeed and cause trouble.
thanks; andy
Miffy
Bromley, London
CLK 320 CAB Elegance C208
No, put a 12v direct feed to the horns, to double check that your horms actually work
Mark A
Aberdeen
58 ML-320CDI.
I had the same problem last year in the ML. When I went to check for a voltage and make sure there was a good contact, the terminals on the horns (both) just fell apart. I got 2 new ones from the local factors for +/- £10 ea and it's been fine ever since. They get covered in a lot of crud where they are located, so I'm not totally surprised after a few years they needed doing.
Mark
