Help..knocking from front drive shaft
matteb63
Abergavenny Wales
Cl 500s & CLS500 with LPG conversions
I have a V class 230 111 engineed ..When I lift my foot off the acelerator you can hear a knocking noise that disappears when engaging drive again... Im worried about the safty issue as I hsve to travel back to Wales with the Kids today..Anyone know what the problem might be?
Thankyou Mattt
djb
uk
in my experiance with front drive mini, polo,golfs etc drive shafts problems first show under load and at full lock, not on the overrun.
take a quick look underneath, usually a little in & out movement is ok however if you can lift them up and down, more than .5 mm then there is a problem.
Might not be drive shaft but diff / box. how fast is the knock, does it behave differently in a different gear. is it a one time knock, or regular withevery wheel revoloution?
matteb63
Abergavenny Wales
every revolution with no knocking under load.or when turning ..just over run..
djb
uk
how heavy a noise? does it knock when coasting in neutral?
knock on overun engine off?
matteb63
Abergavenny Wales
Sorted ..Inner drive shaft to whatever it attaches to ..all the bolts where loose!
Thanks for your replys
Matt
