Help needed for c200 cdi problem!!!
bigiqi
New Registration
hi guys, i have a problem with my car was wondering if anybody out there could give me a solution please. ok my car is a c200 cdi on a 05 reg. a few days back i started to have a problem with the fuses. each time i went to start the car the fuse would blow the fuse was a 15 amp after blowing 5 i replaced it with a 30 amp fuse it has not blown that since but i cannot start the car sometimes. i turn the key and nothing then if i leave it for about 20mins or so it will start but then when i drive the car after 15mins of driving i start to lose power and the car will not go over 3000rpm. anybody out there that can help me please?
Cole@MBS
www.mbssouthampton.co.uk
124 300 CE 24 Coupe, C220CDI,
Was it fuse 51, left rear in the fuse board as you look at it (front SAM) ?
If so then the starter is on its way out, the starter fuse should be 20amp on all C/E classes, MB did a recall some years ago for this,
Welcome to the forums!
Busyboy
i had this problem and was thinking the worst till i read up on this problem on here , anyway new started fitted last week and all is good again :cool:
S-A-M / U-N-I-T
thankyou for the spot on advice , you saved me a lot of p155ing about & money taking the car over to a sparky only to be told the same , :)
