help needed with a part name
joderest
ML270 2003
Dear All
There is a seal at the Turbo end of the pipe that goes to intercooler, a rubber seal, i suspect it may be leaking so want to replace it, any thoughts on what it is called ??
ajlsl600
france
ref description never can tel with benz but o ring seal would be fairly likely whats there or seal ring.
joderest
ML270 2003
or is the Turbo end just a jubilee clip seal, cant seem to find any seals listed for the turbo end.
A6420940080 , do you mean this one? (this is for the om642 engine , but it should give you the correct wording ) put the number into eBay
Bogus
Edinburgh
W124 230E 1992. BMW X3 2.0 d. X drive 2012
Thingumyjig, or whatchamacallit. Not helpful? Sorry, couldnt help myself.
joderest
ML270 2003
Bogus, you need help
joderest
ML270 2003
wighty.
Thanks, not sure, as v6 engine really not the same as 5 pot.
from everything i can see the Turbo end of the pipe is just sealed with a jubilee clip, but i am struggling to find a decent diagram to confirm this.
Oldspanners
Normandy
C CLASS 2004 C180
wighty.
https://mercedes.7zap.com/en/eu/fg/car/m-klasse/ml+270+cdi/06h/163113/m/612963/21t/14/0/030/0/0/
Is this any use not sure what part you need but click on the part number in the diagram and it will give you the part number and description. IF I have given the right link.
joderest
ML270 2003
erm, made a slight error, its the pipe that goes from air cleaner to Turbo, Thanks OLDSPANNERS, think i have worked it out now, there is a "spacer", not sure if its a seal, gives me a start.
cheers
joderest
ML270 2003
Thanks to OLDSPANNERS found the seal, part number A6120940051 engine turbo seal.
It was only £5 delivered, so hope right bit.
Thanks again all
Jim2
joderest
ML270 2003
it is handy, very good, thanks
