Help needed with brake lights
Speednut
Sheffield
2001 CLK 230 AVANTGARDE
Hi need help with above problem, brake lights are on all the time will not go off.
Anybody got any ideas car is clk 230 Avantgarde w208 on a 51 plate
Regards Steve
Hi Steve, unplug the connector above the switch over the brake pedal and see it they go out
Speednut
Sheffield
I assume that the switch is behind the trim, if so might have to wait till morning. If the lights go out then is the switch broke if not what else could cause this.
Do you think it is a garage job?
Steve
Yes just unscrew the cover,,(can give you details if you wish )
then unplug the switch, this is the easiest thing to try first
Speednut
Sheffield
Great stuff, bit more info would be appreciated or a link
Regards Steve
Email address please
I have sent it
Speednut
Sheffield
Disconnected top connecter and brake lights went off left bottom connecter in ,had BAS on display visit workshop, hoping is just switch and is it cheap
Steve
You could join up again and pull the pedal back, to see if it goes out, if not replace the switch 10 and the other messages will go away on their own
Speednut
Sheffield
What do you mean by the term replace the switch 10?
Steve
Speednut
Sheffield
Just a quick update new switch fitted no probs now cheers Malcom for the advice top bloke:D
Steve
www.W140.co.uk&www.r129.co
