HELP PLEASE, p062811 code fault
petemerc
a class a220 2014
Hi all, i have a code fault p062811 and description (the output for the fuel pump has a short circuit to the ground) the car wont start any suggestions please
How healthy is your battery?
If it's old and poorly you may not have enough voltage when cranking for the fuel pump to provide adequate pressure.
On some diagnostic kit you can look at fuel pressures if the low and high pressure fuel rails. You should have 60psi or so on the low pressure and 300 bar on the high side.
P
petemerc
a class a220 2014
Hi its brand new thought it might be the fuel filter housing so i replaced that then because the battery was dead i put a brand new one in and still no change, mechanic is thinking something to do with wires but for that he needs to lift the car up and drop the tank to get to them because they are not under the back seat like in most a classes
