Help Please! With My 380sec (c.reg)
christopher.cross
This is driving me potty? Why is my car stopping after 25mins on a hot day and next day its fine again Ithink its fuel related but what do I change or check ????? PLEASE HELP ME MEMBERS?? Many thanks Chris.:rolleyes:
mattkh
England
A160 W168 1999 1.6
Why do you think it is fuel related ?
Can you describe the stopping ?
As Matt, does it splutter and stop, cut out. A little more please
C
christopher.cross
More Info On My 380sec Fuel Problems
Hi members . I will be more explicit .My merc 380 has been running perfectly until 2 months ago(a hot day) after leaving it for 1 hour it would not start for about 10mins then it was fine.This happenned again a few times but only on hot days (rest of time its fine).Then on wed last week (very hot day) after using her for an hour or so she would not start .then after15mins she goes and I drive normally back to my home but on way home she starts to splutter and seems to tick over ok but when I give gas she just won't pick up?Its very odd but if I turn ignition off then on again and squirt the gas pedal then turn engine over then she is ok for a few miles .However after few miles the splutterring returns.Anyway I get the car back home (nursing it) and low and behold the next day she starts fine and will be ok unless its a hot day and then It will all happen again??? something is breaking down and stopping a smooth fuel flow?I would be grateful for any help members as I'm at the end of my tether and ready to give the car to my merc mechanic.The expensive option which I can ill afford at present.
Kind regards Chris
C
christopher.cross
MESSAGE TO TELEVISION AND MATTKH.
Hi and thanks for your help. When problem occurs and shes in splutterring mode she will tick over fine but will not pick up when accelerator is depressed.
hope this helps also see more info I added previously.
Kind Regards Chris
This is fuel related could be one of the pumps if you have two.
If you have two, take the wire off one and see if it starts, then do the same with the other one, then you will know if you have a faulty pump
They are just behind the off side rear wheel behind a plastic cover.
If the pumps run slow, take them off fill them with diesel and run them backwards. this cleans out any crud and rubbish
star
Reading
Smart + others :)
It cud also be ign related, check the divi cap and coil pole on it, also check coil output, had a few breakdown when hot, also fuel pumps loose pressure when hot, is the pump noisey??
C
christopher.cross
reply to star.
Hi star. No fuel pump is very quiet indeed. Please can you tell me what the divi cap is? Where is the divi cap? Sorry but don't even have a manual for my 380sec and really not that technical .Wish I could get a decent workshop manual for my car? Haynes don't cover this model?? Do they?
many thanks Star. Chris
C
christopher.cross
Hi Malcolm.
Only one pump plus filter in fig of 8 bracket next to rear axle drivers side.Pump is always very quiet. Will try your advice and clear pump.
Regards chris
C
christopher.cross
Hi star Please can you tell me what the divi cap is ?Do you mean distributer cap??? Many thanks for the help
regards Chris
jibcl500
Cambridgeshire
CL500,ML55,SLK280
start looking on ebay germany and USE for a new module, german ebay seems to be cheap on MB parts.
jib
C
christopher.cross
Thanks To All Members!
mANY THANKS TO THE KIND MEMBERS WHO HELPED ME WITH MY RECENT PROBLEMS/ aLL SORTED BNOW AND MY 380SEC IS BACK ON THE ROAD! N:)EEDED NEW FUEL PUMP
C
christopher.cross
HI sENIOR MMEBER THANKS FOR HELP IT WAS FUEL PUMP
TYHANKS cHRIS.
Its a pleasure, thanks for posting back :roll::roll:
