Help please
Smithy 80
A class A200 2013
Hello everyone I have a A class A200 2013 when I start and drive the car normal its fine if I stop at a Junction and pull off accelerating hard not to the point of a wheelspin but giving it some as to move fast the car goes into limp I have to turn off ignition and reset then it goes back to normal I have no light or indication on the dash come up atall but there is a code u041586 Reading implausible data was received from control unit ' traction system ' there is an incorrect signal when I disable the traction control the car drives perfect and can pull off as fast as I like naw I no by disabling the traction control turns off the yaw sensor but does anyone no were its it's located please thank you
John Laidlaw
Wirral
Land Rover Discovery 4
Hmmmm. Reading again the OP's description I'm tempted to look at wheel speed sensor/ABS issues. It really needs to go on STAR to have the codes read correctly. UO415..... looks at the ABS control module. I was distracted by the Op's forum introduction post looking for the YAW sensor, but that's not the issue.... @Smithy 80 where are you located? We can likely point you in the direction of a Mercedes Independent who can diagnose correctly and sort you out...
John Laidlaw
Wirral
Looking like ABS sensor I think....
Smithy 80
A class A200 2013
Thanks john I'm in Telford I really appreciate all the help I can get thanks again
Smithy 80
A class A200 2013
The delivered Drive torque has a malfunction the signal communication is faulty c0073-62 that's the reading off another snap-on diagnostic machine hope this helps a bit more thanks everyone
Impasto
A45
Hi how was this solved?
I had same fault code but only triggered when i was cruising - only happened after long drive
Recently i did a tcu reset (key on key off step on pedal method) and it didnt appear after 3 days driving
www.W140.co.uk&www.r129.co
