Help - Rear Seats in W124
Nelliecat
Hello, I have a 1995 E220 (W124) seven seater. How on earth do i recline the rear seats ?? There is a built in dog guard / luggage cover attached to them. Do not have the manual so a bit stuck. Any help appreciated!!!
marshie001
Ipswich
i was in the same boat a few weeks ago!
if i remember correctly there is a black handle under the seat (bum section) on each side! its well hidden, you just lift this,sit the bottom up first, this will then release the backs, which are independant, the dog/luggage cover is attached only to the larger side! hope this helps.
N
Nelliecat
success!!!
thanks very much, was fiddling with that handle but thought it just released the lower part of the seat. cheers. :mrgreen:
marshie001
Ipswich
your welcome, i was struggling with mine for about 2 hours!
the backs may well be a bit stiff if not used for a while as mine were but give them a good thump and they should give, the dog guard slides off out the rear door then aswell if you dont need it!
N
Nelliecat
thanks
they were very very stuff - bit of WD40 and both feet!
marshie001
Ipswich
lol mines a 1989 and i dont think it had ever been down!!
i thought it must be the same,once the bottom bit is up you can see the two catches that are released to allow the backs to come forward.(they look like little clutch pedals!) easy when you know how....pain in the $*%& when you don't!!
N
Nelliecat
wheels
got any advice re wheels - got a set of 15 in merc alloys but they look a bit puny (like the new 5 series with standard wheels). will any merc wheel fit or do you need to enter the strange world off offsets and the like ??
ps bulb gone on instrument binnacle - easy job or complete weekend to change ?
marshie001
Ipswich
ive got 15 inch after market alloys on mine, i think most mercedes wheels will fit,some probably will need spacer kits (ie a class) but if you follow the link it will show you exactly what the pcd and offset of each car is so you can determine the fit yourself...
http://www.alloyguide.co.uk/
theres been a lot of discussion about wheels in the past. ie losing/comprimising ride quality, if you use the search facility at the top of the page and enter alloy wheels you'll probably find what you need! as with the instrument binnacle bulb change, most things are covered somewhere.
