Everytime i suspect i have a battery drain I connect up a multimeter, in series to the battery and try eliminate drain by pulling fuses and various components untill the current reading drops to manufacturer spec.
But this always seems to blow the fuse on my meters. I understand that this is due to the surge of current going through the meter being more than the fuse amperage in the meter. I was using a 20amp max meter. and changed to a 30amp max meter, still same problem.
The question is How can I measure amps draw without the risk of blowing meters and get an accurate figure.
I have tried using my pico scope and can not make head or tail of the readings. Although thats my fault because Iam still coming to grips on how to use a scope properly.
can anyone tell me the correct amp clamp to use for the this procedure using the picoscope and exactly how to connect it up and interprete the data.
alternatively the CORRECT way to use a meter and not blow the fuses, or is there another too I can use ????
thanking you all in advance.
