Hi, People,
This demon came to me from another garage vehicle will not crank all lights come on dash.
Garage replaced starter motor - still no start
in the battery tray is a black plug with 2 wires if you put a live to the violet and white wire, vehicle will start but once turned off can not be restarted unless same procedure is carried out. if you leave the ignition off for 5mins and turn it back on, there is a clicking noise from behind the dash for approx 10 secs
This vehicle is a manual and i can not find a starter motor relay, I dont think it has one. even though I can not seem to find the correct wiring diagram.
I have checked the ignition switch and removed the switch that goes into the back of the ignition switch checked all seems ok.
all the signals seem to be fine but no live to this violet wire with white tracer
I know one end goes to the starter motor.
Does any one know where the other end is supposed to go/come from, I know the wire is the signal for the solenoid to turn the starter, the das enable signal is being recieved, and no start error on dash. I have tried to physically trace the other end of this wire but it goes up under the centre console and behind the dash and disappears ????? any contributions would be much appreciated
