Help. Reversing camera
gulab100
Vito 116 sport Dualiner LWB
Hi all,
Reversing camera packed up in the frosts over winter. Water in the connector. Needs to be replaced. Can't seem to find a part number. MB want £347+vat. Need to look second hand.
Vito 2013 116 sport dualiner.
Any suggestion would be welcome.
Thanks in advance.
Rupert
Hello and welcome,
I'd expect you could replace with an aftermarket camera - just need to check if you need an NTSC one as Mercedes tend to use NTSC (rather than PAL) - (yes even in UK and Europe)
G
gulab100
Cheers Blobcat and thank you. Will have a look at that option as thats a lot of cash indeed. R
It’s a serious amount of folding, I’d have the connection apart and check if it can be salvaged. If not a “cheap” Chinesium one would be getting fitted.
I’ve toyed with sticking one into my Comand (I’ve 3 Kenwood ones sat on the shelf in my garage from previous installations in vehicles)
G
gulab100
Blobcat.....Just pulled it all out, the wiring in the connector is v badly corroded. The camera may well be alright. Perhaps I can get the little loom with the connector? Cant find a part number though???? For the camera or the loom. Merc refused to give it up.... which I guess is their perogative.....
G
gulab100
can you show a photo of the problem corrosion ? maybe it can be cleaned up
Hi Anyweb,
Photo attached. Absolutely shot. Although I did try, the pins are wafer thin and just bend. No way to re-attach.:( The connector on the camera end had a slight split in it and had let water in. I think the cold in december froze that water. Appers that the little loom that has this plug is not available seperately. In other news, I at last found a part number: A6398200597. Appear to be none available secondhand apart from one in Lithuania that's more than the new off Merc. Oh well. Keep searching. Thanks
ajlsl600
france
If u can count the pins u can buy the connectors / plugs (duetz) for example online.or If memory OK from bosch just make sure u know which crimper to get as well or go to a good auto shop with car and camera and pay attn to any holes in bodywork the block must pass thru
G
gulab100
Hey ajlsl600, Thanks for this. I'll check it out!
s5tuart
2003 R230 SL350
Those connector pins should just pull off after a good douse with something like electrical switch cleaner then, as above, buy new pins, crimp on the the existing wires firmly, shield with sleeving and re plug
Jobs a good 'un
