Help. Stuck in 2nd gear.
rbatt
Help. My 2000 C220 is stuck in second gear. It got stuck in 4th last week but it corrected itself when I restarted the car. The tiptronic type gear change doesn't work and the gear indicator just remains on "D".
My instrument cluster has pixel problems so I cannot read it properly. But there are no orange light or warning triangle.
I've got the AA coming in the morning.
Any ideas??
I have answered your other post and this should just be the speed sensor plate that has failed
R
rbatt
Thank you. Easy to obtain and fit? Expensive or pennies?
rpe2
Silchester
About £350 fitted by an indie
Some do it for £300 do ask first
R
rbatt
I also posted on the electrical part of the forum. Someone suggested low oil levels. My pixel don't work but there have been some random warning chimes at different speeds. Would low gearbox oil produce a warning chime?
No sir they would not
miknik
Berkshire
www.mercanix.co.uk
Vito 111CDI LWB
No, but nor would a faulty speed sensor on the electrics plate. My money is on the speed sensor, 9/10 times this is the problem. Parts cost is about £140 for a new electrics plate, you might as well do the oil and filter while you are in there.
R
rbatt
AA man didn't have a fault code reader!
He reckons that it's the torque convertor?? Due to the way that the gearbox clunks into 2nd gear.
Anyway it's off to my local indy behind the AA van
I doubt it very much
R
rbatt
Indy just called. Speed sensor problem (as suggested on this forum). Approx £320 fitted.
Just put it sown to bad luck,,and that price is good and OK
