robs-mbz
- Dec 9, 2006
- Location
- Newcastle under Lyme
- 1997 E300TD
Help Guys!
My up to now 100% fault free E300 TD has a fault!
I gently turned right out of a junction the other night and my BAS/ASR light came on followed by the BAS/ASR warning on the display. The fault is still there, when I first switch on the ignition all is well with no faults displayed. When I start the engine the BAS warning comes on followed about 10 seconds later by the ASR warning. The car drives and brakes ok.
I have read that the foot brake switch can cause this problem. I have removed the trim panels to gain access to the switch. Everything looks ok, no loose connections that I can see. The rear brake lights work as they should.
Questions.
1, How do I remove the switch?
2, Can I test the switch for faults once removed?
3, What else can cause the fault? (sensors?)
Any help would be appreciated!
Questions.
