Help warning lights R129 320
jolly
Hi i need help i have a sl320 1998 i have warning lights constantly on they are BAS ASR and ABS i also noticed hat my hazard lights flash on ther own ramdemly this happens when i am parked up and out of the car i have noticed this 3 times but this could be happening more often when the car is not in sight opps nearly forgot the cruise control has stopped working about the same time as lights have appeared :(:(:(
For the ABS and other lights, do check the OVP relay,, from memory if it is a face lift car,mid 1998 it could be in the boot,,and it has a fuse on top.
The hazards could be the alarm, the CC is all part of the ABS fault
Check the fuse and we can take it from there
jolly
Thanks Malcom i will try that and will let you know
kth286
E320 Coupe 95
Brake light switch - it is dual purpose.
Cheap.
The brake light switch for BAS and ESP but not when ABS lamp on and no CC
If not the OVP relay then a front wheel sensor as the speed signals are taken from the front wheels
