HELP!! Water pump gone.
mercmadjim
Cornwall
SLK230k
Hi guys (Malcolm :)) the water pump on my 300 TE has gone, is it an easy job? anything to watch for? any idea what a pump costs? is the belt easy to remove? well basically any advice/help at all please.
Cheers
Jim.
no problem,do you know what engine you have.
I do recommend that you get the spline sockets as the nuts bolts can be tight
Smudge
Not difficult, but is time consuming. Make sure you bleed air out well after filling with coolant. Also make a note of route of the serpantine belt
mercmadjim
mercmadjim
Cornwall
SLK230k
When you say what engine I presume you need a code or something? its a 3ltr straight 6, chassis number WDB1240902F109639.
Thanks.
mercmadjim
mercmadjim
Cornwall
SLK230k
Thank you Malcolm, you truly are a gent sir.
2 papers Emailed to you,I do not think that you need more
mercmadjim
mercmadjim
Cornwall
SLK230k
Thanks Malcolm, seems straight forward, how do I release tension from the belt??
Just undo the 17mm nut on the top of the rod
Cosworth
Just be careful of the water pipes the connect to the pump they can be rusty and may get stuck.
Thanks for this,I did see there is a paper for this problem, I must read it
mercmadjim
mercmadjim
Cornwall
SLK230k
Would that be the nut just above the water pump, which looks like it adjusts the power steering pump? which on mine is 13mm and seized solid?
And what is the Chinese puzzle that is called the viscous fan? I can't remove the cover because the fan is in the way and I can't see how to undo the fan because of the cover:confused::confused::confused:
What cover, do you mean the shroud that cover the rear of the rad
mercmadjim
mercmadjim
Cornwall
SLK230k
Thats the one Malcolm, it clips onto the back of the rad, to stop people like me touching the fan!!
mercmadjim
mercmadjim
Cornwall
SLK230k
  • #19
Paper recieved, thank you Malcolm, just one more question (for tonight) how do you undo the viscous fan??:confused:
www.W140.co.uk&www.r129.co
