- Mar 7, 2013
- Location
- Stamford
- CLK 200 Kompressor
WILL WATER SOFTENERS DO THE SAME THING AS A WATER FILTER?
Water Softeners change dissolved hardness into dissolved sodium bicarbonate which removes limescale. However, if you boil off the resultant water you will have a residue at the end of the process - which will be left on your car if you use softened water to wash it and let it dry in the sun.
Race Glaze water filters totally removes all dissolved solids and there will be nothing left on your car after sun drying. They are different process designed to do different things.
