Paulgeorge01
- Jan 20, 2020
- Location
- Spey bay, Fochabers.
- Sprinter 311 CDI LWB extra high 01.12.2008 2148 cc OM646.
Hi All,
Newbie here, just joined the forum. Proud to have a Mercedes, although just a van .
I would greatly appreciate some information regarding the following questions. Any answers are a bonus as it all helps, thanks in advance for any replies.
Am heading off later today to pick up 2008 sprinter 311 2.1 CDI I have just bought. The van is presently not in a driveable state, I need to sort out the brakes. Work scope as follows. Ensure no sticky pistons (repair as necessary), new disks, pads, and wear sensors on all 4 corners - this all came with the van, displace complete system to fresh brake fluid - still need to purchase fluid.
Front and back floating caliper slide bolt torque please? I am guessing the same bolt size and thread pitch on both front and back.
Caliper carrier to bearing housing bolt torque please? I am guessing there may be a difference in bolt sizes between the front and rear calipers.
Is bleed sequence standard for UK vehicle with master cylinder on OSF i.e. NSR - OSR - NSF - OSF?
Brake fluid type please? What is the capacity of the brake system including the brake expansion tank? I was going to get 2 litres, would that be enough to give all 4 corners a good flush out?
Much appreciated,
Paul
Much appreciated,
Paul
