gliggsy
Hi guys, I'm going to ask the question even though it's been done to death but here goes.
The car's a 2007 Cls320 diesel, it started going into limp about 2 years ago with p2044, generic turbo fail code I believe. I carried on using it because it wasn't too inconvenient to just recycle the ignition until 6 months ago when it got progressively worse to the point of having to have it repaired by MB specialist indy. The turbo actuator was diagnosed and a refurbished one fitted, car was fine and performed perfectly well for a month, took it back to have it diagnosed again and another unit fitted(warranty). This 2nd unit has done exactly the same, a months work and failing already, garage has been informed and have requested to delve deeper. Egr has been out and was spotless, new air filter fitted and exhaust pressure switch fitted. I will be taking it in for repair but was curious if anyone could shed some light on to why it's failing and why it should run perfectly for a month? The problem is worse when the car is cold but won't limp again once re-set..... Baffling
