help with plugs and maf
Gt Russell
Newcastle Upon Tyne
CLK 200 Kompressor convertable
Could someone please tell me the torque setting for the spark plugs in my CLK 200 Kompressor its a 2002 model also where is the Maf located as I want to clean it with Isopropryl
nickcc101
Helston Cornwall
Plug torque. Up to 20/4/04 25NM, from 21/04/04 28NM. (as S-A-M /U-N-I-T above).
G
Gt Russell
Newcastle Upon Tyne
Thanks guys thats a great help
So this weekend will be oil and filter change clean maf with isopropryl new spark plugs , new air filter bleed brake fluid next week change trany oil and filter and wax car :D
Oh and do the coilpacks need torqued ?? If so what is the torqe for those please
nickcc101
Helston Cornwall
Would also suggest cleaning inside throttle housing if removing air intake pipework, found loads of sticky black build up under butterfly which triggered 02 sensor fault code due to mis-fuel.
Cole@MBS
www.mbssouthampton.co.uk
Again from memory, 6NM
Back in the 20's there was no such thing, the torque settings for RR cars was done by the length of the spanner, so we used a 4½" long one for manifold nuts, and an 8" long one for the head bolts, the spanners for the electrics were 2" long and BA threads, what useless info;)
coventryslk
Coventry
W204 CDI Sport
so my m111, slk 200k is 25nm? What is the torque for the red rocker cover bolts?
