help with reversing camera
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by Georgius, Nov 28, 2012.
  1. Georgius
    Georgius New Registration
    Nov 17, 2012
    Edinburgh
    Your Mercedes:
    B200 sport
    Hi all first post on the site, so sorry if i get it wrong.
    I have a b200 10 plate and i want to fit a reversing camera, do i just need the camera and plug it in or do i need to get software and fittings for the back of the command unit.
    The unit has the sd card apart from that i know not much about it.
    Where is the best place to get the camera and anything else that i might need or can i get a kit?
    many thanks for any advice
  2. whitenemesis
    whitenemesis Senior Member
    17,978
    22
    Dec 21, 2006
    Your Mercedes:
    CLS55 AMG '05
    These guys can supply everything required, plus fitting and or advise.
    comand.co.uk
    You will probably require the wiring loom and some coding to tell the car what's been fitted.
  3. npuk
    npuk Guest
    You need a fakra to rca video cable available on ebay and a camera, thats all. STAR coding is needed to enable the fakra input and Comand will automatically switch to the rear view camera when reverse gear is selected.
    http://forums.mercedesclub.org.uk/showthread.php?t=88426
Share This Page
