Here we go... It was inevitable.
Stu_CDX
Essex, UK
With everyone having issues with substitute lights and bulb warnings, I got the bulb warning light come on today.
Now... It's driving me mad.
I've checked EVERYTHING.
Indicators, hazard flashers, reverse and tail lights. I've only got one fog light on the back but there's no bulb in the other one and it hasn't flagged up before. The remaining one works.
Then, there's the headlights, all fine there.
I recently replaced the tail lamp bulb on the passenger side, with a Mercedes part. Nothing askew there.
I'm hoping the W124 is too old for SAM's and so on, so what's up?
I really have checked everything. There is NOTHING wrong. After a restart, it can go away and not come back.
I'm really not sure what's up with it.
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
Number plate lights are the favourite
Try replacing the rear sidelights bulbs first. Then go through the car replacing bulbs in pairs till you find the problem. If you can't find a problem then the bulb failure relay is probably kaput
At what point does the failure lamp come on?
Nick Froome
www.w124.co.uk
Stu_CDX
Stu_CDX
Essex, UK
Nick Froome
www.w124.co.uk
Whenever it wants. It only happened when it got cold.
It comes on sometimes when there's no lights on.
The number plate lights are fine as are ALL bulbs on the car :mad:
Just went to the shop and back, nothing came on.
malcolm E53 AMG
It might be worth checking that all the bulbs have been replaced with the correct voltage/Watt. Had this problem with mine and it took me a while to find out that I was replacing like for like but when I checked the bulb chart in the handbook the previous owner has put in the wrong rating replacement.
roofless
w124 e220 estate
i had it with my 124 last year & it was the bulb holder faulty on the rear light
roofless
w124 e220 estate
I'll give it a clean up with some wire wool.
Cheers.
i think it was one of the terminal was sticking down when the bulb was pushed in but seemed to make intermittent contact & the dash light would come on with a mind of it's own :D
If it comes on when driving without the lights on the this reads as a brake lamp fault, do check the ground / earthing wires
