Hi everyone
JerryStringer
C220cdi sport 57 plate 2.2
I have a c220cdi w204 sport on a 57 plate and I am have issues with high fuel pressure fault and car going into limp mode has anyone else had the same issues if so what did you do to rectify it thanks
SmartAmg
2011 E class coupe 350 CDI
Welcome, Jerry. :)
Hello and welcome
Srdl
Hampshire
GLC43 AMG 2018 (X253)
Welcome to the forum
00slk
Cambridgeshire UK
Hello and welcome, hope you get sorted.
A.J.
Norwich. UK
Hi Jerry, welcome to the forum :)
antony777
c class w 204 c220 cdi
yes i know your pain as ive had the same problem i changed the sensor on the fuel rail small one at the front , it has a number like 55pp02 on it . that might be the problem . i have changed the fuel temp sensor located under the high pressure fuel pump put a genuine new fuel filter on and still do have problems ive got to the stage now of fitting a second hand fuel rail £60 from a breakers yard . The rear of the fuel rail has a regulator at the bulkhead end ill let you know when fitted . Ihave noticed that on my car it does not fault when fuel reserve light comes on . hope this is some sort of help
www.W140.co.uk&www.r129.co
