Hi, I'm Winno from Namibia with a B170: 2005
Winno
B170 of 2006, reported transmission consult workshop, fun noise and slowed.
Transmission consult workshop on screen warning, then speed reduced and fun noise. I parked later I drove it perfect again. I am worried,
mattkh
England
A160 W168 1999 1.6
What were the exact circumstances when that message popped..?
W
Winno
W
Winno
It broke the outer CV and it overstayed without being switched for over a year and 8 months. I recently fixed it and it was crackling and not restarting the engine. It was discovered with a scan that it was a fuel pump jamed. The mechanic resolved it and it started running. It's then began complaining of a transmission consult workshop. And the speed is reduced with fun noise. Thanks
mattkh
England
A160 W168 1999 1.6
......it overstayed without being switched for over a year and 8 months.
Thanks very much for the detail.
What does your mechanic feel about changing the transmission fluid..?
W
Winno
I just discovered that the mechanic did put a CVT fluid in my gearbox instead of ATF 1200. There are Strange engine sounds such as clunking
Stalling after changing gears
Gears that won’t shift
Rough shifting
Gears that slip
Clutch locking up
So How Long Do I Have?
W
Winno
Rough shifting
Gears that slip
Clutch locking up
SL63 Mark
The South
R231 SL63 AMG
What does your mechanic advise ? Maybe drain and flush and new fluid ?
Tel: 020 8863 9233
