Hi newbie here
Emma80
A class cdi 2013
I’ve got a 2013 reg Mercedes a class 220 cdi.
Everything works fine apart from the navi when I press it it says no navi module connected. Help please do I need to buy something for it or is it a disc? There’s nothing in the glove box that I can find to put anything in as I’ve seen in other threads.
Hello and welcome
As likely as not it’s the card that’s missing or not plugged in, in the centre armrest
SmartAmg
2011 E class coupe 350 CDI
Welcome, Emma. :)
A.J.
Norwich. UK
Hi Emma, welcome to the forum :)
E
Emma80
A class cdi 2013
Thank you I’ll look tomorrow at the arm rest.
Thank you for accepting me on the forum
Srdl
Hampshire
GLC43 AMG 2018 (X253)
Hi Emma and welcome. It sounds as though you have the Audio 20 system which would have had Map Pilot (probably Becker Map Pilot for 2012) as an option. if you have the pre-wiring, then it is just a case of getting a suitable second hand box and adding it (make sure you get the PIN code as they won’t work without it), However, of there is nothing in the glove box, then you don’t have the wiring so it could be very expensive to add.
Do a VIN code check at https://www.mbdecoder.com/. From memory, I think you need code 508 which is the pre-installation factory fit. Without that, you will have problems.
E
Emma80
A class cdi 2013
E
Emma80
A class cdi 2013
This is what’s on the inside of the arm rest
