Historic Fault Codes (23EA, 200C, 200B, 22E0)
Jonas361
Mercedes Benz (S211) E220 CDI, 09/2006
Hi everyone,
I'm Jonas and driving an S211 E220 CDI (2006) and just read my Fault Codes. I got 4 stored in the ECM. Since they are all historic can I just delete them and check if they come back? I recently replaced my V-ribbed belt because it was cracked - could that be where the errors are coming from? Thanks, everyone.
BENZ_EN_TEST_00005>E(211)>As of 06-2006>T-Model>Diesel>211.208 - E 220 CDI>Smart Scan>ECM - Engine Control Module(CDID)>Read Fault Code:
Total Number : 4
23EA 1/4
State: Historic
Check component N14/3(Glow output stage), No signal
200C 2/4
State: Historic
Test components B6/1(Camshaft Hall sensor) and L5(Crankshaft position sensor), Crank angle position sensor, assignment of crankshaft and camshaft signal faulty
200B 3/4
State: Historic
B6/1(Camshaft Hall sensor) No camshaft signal
22E0 4/4
State: Historic
CAN signal 'Vehicle speed' from control module Electronic stability program is unreasonable
mattkh
England
A160 W168 1999 1.6
Yes, delete and see if they come back.
Is the car running OK...?
What is the mileage..?
Jonas361
The car is running fine so far, I had the check engine light once but it went away after a few starts. Mileage is 278,000km / 173983mi
Nothing to do with the belt but if it's cracked change it.
As for the codes just clear them and monitor for their return.
Jonas361
what code reader are you using
I'm using the iCarsoft MB v2.0 for diagnostics.
Concerning the belt, I already replaced it - thanks to everyone for your replies. I'll clear the codes and will check if they come back and let you know
