Hmm, wiper maintenance.
GarbageOverlord
E280/1998/M112
So yesterday, I had to do a drive in the rain (eeek, more rust!:shock:) This meant using the wiper properly in anger for the first time since owning the car.
This highlighted 2 things.
1. The appears to be some kind of rain sensor - really? The wiper worked more in heavier rain than lighter rain. Amazing for such an old car.
2. It sounded very clunky and noisy. Qué watching YouTube videos and learning about greasing the mechanism at the base of the screen. (It also made me realise that there is a plastic cover missing at the bottom of the wiper arm which likely will let in water).
Now I've gobbed in loads of grease to the "jumping" part but I have a feeling there is wear in the linkage mechanism. I'll have to keep an eye on that
As for the missing plastic arm cover, well they appear to be made of solid gold judging from the price of a replacement - 50% of what I paid for the car!o_O Hmm. I've ended up buying a second hand arm from eBay just to get the required bit of plastic.:rolleyes:
Can't really make up my mind whether 2 wipers are better than one, buts it's clever. Mind you I did read that it only clears 6% more of the screen than conventional setup, which seems a small gain for likely huge development money...
C16RKC
Wisbech
www.youtube.com
2003 CL500, 2007 S320CDi
Glad you are getting stuck in with the Mercedes ownership repairs :p
I love those older Mercedes with single wiper arms that jump up and down to clear all the screen.... sadly I have only ever owner the "2 wiper" versions. I wonder why they changed?
I might have remembered it incorrectly... but I think the W220 had two arms but the passenger one still did the "jump" to help it clear a bit extra. I might have got that wrong?
brandwooddixon
Wolverhampton
S63 Coupe 2014
A warning as regards noise, if you get a clunk type noise at the top corners of the windscreen, it's likely that you have an ill fitting wiper blade fitted. I found that a lot of the cheaper wiper blade fittings don't take into account that the wiper blade is pushed and pulled along the axis of the wiper arm as it sweeps the windscreen.
Cheaper to replace with 2 :(
GarbageOverlord
GarbageOverlord
E280/1998/M112
Hmm, interesting info. I actually tried to replace the blade but the eBay seller sent the wrong size, and didn't have the correct one. However the current blade is fine for the moment.
Good thread below:
Pictures gone from the below, still useful info though:
GarbageOverlord
GarbageOverlord
E280/1998/M112
Good thread below:
Yes, that's pretty much what I did, larded it full of Lucas Red n Tacky grease, excellent stuff.:D
Doug1234
Bedfordshire uk
1997 w210 e300td
How thick’s the Lucas red grease ? , you may get issues in cold weather ( winter ) if it’s too thick
GarbageOverlord
GarbageOverlord
E280/1998/M112
I'd say it's no thicker than any other yellow grease (of which there were some remains).
I use it because it came out top on one of Project Farms rigorous tests.:)
