philharve
- Jan 20, 2005
- Age
- 73
- Location
- Falmouth, Cornwall, United Kingdom
- Website
- go.to
- W202 C230K Auto 2000
Hi All
I have a C230K that will go into the bodyshop at the end of April for some minor repair work to the leading lower corner of a rear door. I am also contemplating having the trim pieces on the B posts repainted because they are exhibiting early signs of rusting, mainly along the edges. It's a minor problem at the moment but the rust will spread. Since the car has to visit the bodyshop I may as well kill two birds and get the only remaining rust spots treated ... until I next wash my car and discover a new one.
These trim pieces appear to have a 'carbon fibre' effect on them to match the effect around the facia. This suggests to me that the outer surface of the trim pieces may be some form of transfer that is stuck on rather than painted. It's not immediately apparent to me how these trim pieces are attached to the B post. Are they pressed on and are there pegs behind the trim that fit into recesses in the B post? Repair would seem to be a very simple job?
Has any member had these trim pieces repainted/replaced? How easy is it and approximately how much is it likely to cost? I will have it done professionally so the repair should last a very long time.
Regards
Phil
Regards
Phil
