How do I remove and replace alternator for 2003 E320 CDI W211
moonmin
Hi, does anyone know exactly how to remove the alternator of an August 2003 E320 CDI (automatic diesel) WDB 211 model? Any help and/or ideally diagrams/manuals would be brilliant! Thanks :eek:)
I can give you the info that you need, and as Ollie above, what is wrong
Retro_Gamer
New Registration
W211
Hi Television. I have a Mercedes E270 Diesel W211 Automatic. I have replaced the battery 2 weeks ago after I had problems with the battery dying. I bought a new battery and it is happening again. I got the AA to come out, and they told me it is the alternator. Is there a tutorial on how to replace the alternator thanks?
wireman
lancashire
Open a window fully (see end of story).
Disconnect the battery ground strap.
Take off the fan belt.
Take off the wiring at the alternator.
Take off any undershield.
Take out the alternator securing bolts.
Lower it out and there you have it.
Re-assembly is the reverse of the above.
When reconnecting the battery:-
Keep the key in your pocket, sometimes the security system can lock the car when the battery is being connected, or you could leave a window open just in case.
Mine did and I didn't, but the spare key was handy.
It may be possible to change just the reg pack but need to be sure that you have the right info, there is also the possibility that you have a water cooled alternator
Can you pop up the next 3 numbers after 211 please.
If you can just change the reg pack it will be a few hundred ££ cheaper
sharjah
derbyshire high peak
1994 sl320 r129/r230 sl500 2003
211 alternator
Hi, the VIN number is WDB2112262A377288. Im led to believe its a water cooled unit. Its not noisy when running so with luck I can repair it,getting off is the problem. I have access to a ramp at weekends.
Naraic
2005 CL500.
What's your question?
sharjah
211 alternator
Hi, the battery / alternator warning light is on and warns of low brakes. thanks.
Do you have the car model number please
Nailzy
Bridgend
W211 E320 CDi
Malc - datacard says it's a W211 E320 CDI ( 211.226 )
www.ckinsurance.co.uk
