how to adjust the door
kbekl
manchester
1998 E300td
when i close the drivers door softly it will latch but not fully close unless you push harder
it seems to be catching on the plug bit (want for a better word) as it has some marks on the top
the joints seem fine and have no play ie door wont move up or down open or nearly closed
is it a simple tighten up or does it go a bit deeper than that
kbekl
kbekl
manchester
1998 E300td
it seems to be
so its a matter of loosening it and the move then tighten or not
Those plate are often on serrated groves, you do not want to upset the height of it, so just put a piece of tape top and bottom on the B pillar, loosen the screws and bring it back one notch and tighten, and try that
