And welcome to the site Urim!!
I forgot that one
Hello and welcome to the forum
Remember what?You cant remember everything Malc
Always a good idea to start any enquiry with your exact MB model with its age. Saves time and possible erroneous information. e.g. if you read the posts Malcolm suggested you will notice later MB auto transmissions do not have a torque converter drain plug and require a different technique to change the fluid completely. AND DON'T repeat don't overfill as that can damage the box as much as underfilling it. Follow the instructions on checking the level exactly.
Dont over tighten the sump bolts, they strip very easy, and make sure you wear a rain mack, you will get drips of oil everywhere!!
Oh, and remove the filter with a long bar, it also hold a load of oil!!
Good luck!
Forgot that bit the other day as all the atf ran down my arm and i had nowhere to go!
Lynall
Where do you live so someone can recommend a good IndyHi
I have a e320 2007 CDI with no gearbox dipstick? Is the ATF easy to change in this type of box? Thanks for the advice.
