Parrot of Doom
- Nov 14, 2005
- Location
- Manchester
- Was an E300TD, now a Lexus LS400
Tools required:
2 new discs
Trolley jack or Mercedes jack, 2 tonne axle stands
Wheel brace
16mm ring spanner and 16mm ratchet
Big lump hammer
Pair of adjustable grips/pliers with at least 2 inches clearance
Wire brush and sharp chisel
Copperslip grease
Degreaser
Paper towel
Swear filter
If you've ever changed a wheel, this job isn't that much more difficult than that. Its a pretty simple job, and just requires a bit of brute physical strength.
1) Park the car on level ground, apply the handbrake, put the car in P, turn off the ignition
2) Get your wheel brace out and loosen the bolts to finger-tight levels.
3) Jack the rear of the car up on one side, and put your axle-stand underneath the large rubber jacking point. Let the jack down slightly, and let the axle stand take the strain.
4) Remove the 5 bolts from the wheel, and put the wheel to one side.
5) The next thing we have to do now is remove the calipers.
I is better to retract the pistons at this stage, otherwise the pads may jam on the ridge on the outer edge of the disc. The calipers hold the brake pads in position, and are bolted onto the rear of the wheel hub. It is only possible to remove the pads when the caliper is off, with the exception of cars like the 211 where they have the same double pins as on the front. With this type of caliper you must remove the pads first, by knocking out the 2 pins, then withdraw the pads. To retract the pistons into the body of the caliper, the best way is to undo the bleed nipple, and using a large flat screwdriver between the pad and the disc force the piston back - and then tighten the bleed nipple. It is possible to do this without adjusting the bleed nipple, but its easier not to. Do keep a check on the fluid reservoir under the bonnet so that the brake fluid does not over flow. Don't worry about damaging the disc or the pad as you'll be throwing them away.
At this point, just double check the car is securely raised, since from now on your head is going to be under the vehicle.
Here are the bolts, on the inside of the disc. Some calipers have a different design with 2x 7mm allen bolts behind a rubber plug.
There isn't a lot of room in there, so you'll either need a short socket, or a ring spanner. Either way, the bolts are 16mm. What I do is get my ratchet on the bolts and use that to remove most of the tension. Once they're coming loose, I change over to the spanner as my sockets are too long to unscrew the bolt all the way out. If you have calipers with allen bolts, you may need a bit of pipe or something to extend it to get leverage - a ring spanner is good for this.
You might find it easier with a 11/16ths spanner once the bolt is loose, it makes it easier locating the bolt and helping free it. After a few turns you should be able to unscrew it with your finger and thumb.
Now to remove the caliper from the disc. The bolts are out, but the caliper is stuck fast to the disc.
Just a few light taps to help it free if necessary. Once it moves a little, grab hold of the caliper and work it free. Tap it a few more times if necessary. The pads should be loose now, pull them out.
When the caliper is free of the disc, wedge it somewhere in the suspension behind the hub, or if you can't find a place, just get a tin of paint or something tall, and rest it on that. Try not to let it hang via the brake line. You could also hang it from a piece of wire, or twine.
6) Now to remove the disc.
In normal use, the disc is held on the hub by the wheel bolts. Theres a little allen screw that stops the disc from falling off and breaking your foot. Thats all its there to do, it doesn't have any other function. It won't be tight, so unscrew it and put it to one side.
2 new discs
Wheel brace
Big lump hammer
Copperslip grease
Degreaser
Paper towel
Swear filter
