hawk20
- May 27, 2006
- ML250 BlueTEC Sport
kth286 said:Normally, leave in D and foot on brake.
But if stop looks longer then into N and keep foot on brake.
The benefit of N is that it allows engine to rev slightly higher and in very hot weather it moves the coolant around better reducing hot spots in the engine, and also allows alternator to charge better.
Do not like the idea of going into P at all !!!!!!!
Is this really what Advance Motorists say? It looks like self appointed 'experts' making life complicated just for its own sake, to me. I drive a Mercedes which is perfectly capable of cooling itself without such shenanigans. By the way the difference in revs from D to N is almost imperceptible -at least on mine.
As for the alternator charging better, I don't need it to. It does the job fine driving as the manual suggests.
I don't know if you have ever been shunted up the back, but sitting with your foot on the footbrake for long periods as you describe, may increase rear end shunts. When you are hit, the surprise and thump makes you let go of the brake. You then shoot forward and hit the one in front. You may well be deemed to be partially to blame as you should have applied the parking brake when stopping for longer periods or at the least gone into P as others describe.
Finally, as raised by others, on drive by wire accelerators and whether we can left-foot brake while the right foot does the accelerator, some say that the foot on the brake cuts off the accelerator. Well not on my S220 series. I can definitely use both together and I think it useful at times to have that facility.
