mlc said:grow up and behave like an adult
definition of Adult:
Big Kid who has forgot how to have fun! = boring old ****.
C220GJS said:The problem is probably material transfer from pad to disc or vice-versa rather than warped discs, which is highly unlikely with ventilated discs.
Silver Arrow said:I think that I have only ever replaced 4 disc in the hundreds of cars that I have owned.
Malcolm
Ummm. My wife's old 240 Volvo estate is manual, and she says that the is the only sane driver in the family, but that has gone through two sets of discs in the last two years. We have had it from new (1989) and the earlier sets lasted several years. I have gone through 1 set in my XJS but it don't get that much use. On the second set in the Quattro, (Manual, but lots of Extra Sensory Perception which takes over everything). Coupe seems OK, but the rears need a polish occasionally if it hasn't been out for a bit. Lotus calipers stick if left in the garage overnight!
Agreed, I don't use 'P' unless I'm parking as the reversing lights flashing on when going through the gate confuses those behind.Myros said:D, parking brake on, footbrake covered and used to warn approaching traffic from the rear. Except when we could see we'd be there for ever, when N, or engine off would be more appropriate.
or was that just me?
Handy things forums.so many veiws and thoughtsmike65 said:I never thought of that!
Mike.
thespirit3 said:Pull up at traffic lights (anticipating a long wait). Use the handbrake (well, footbrake - but you know what I mean!).
Should I leave the car in 'Drive', or move it to 'Neutral' or 'Park'?
Coming from driving a manual, the combination of handbrake and 'drive' doesn't seem all that healthy. But I've read elsewhere that moving from D to N/P causes unnecessary wear on the linkage, and in some cases can cause extra wear on the box - due to oil not getting circulated properly.
Common misunderstanding.CMR said:C240 is my first auto as I've always driven manual cars. So if I'm at lights or stopped for a while in a queue I have been putting it in Neutral as you would with a car with gears (sometimes with footbrake if neccessary (not handbrake). Holding an auto in drive with the footbreak equates to riding the clutch on a gear car (like you may do on a hill in slow moving traffic) but is often advised against due to wear on the clutch. I don't know enough of the mechanics of an auto if this is the same kind of thing so should I not use neutral at all and just hold it in Drive with the footbrake? Which method causes most wear?
wireman said:Some of the above advice is attrocious.
Try reading some books about driving properly and you will be told that the vehicle should be in neutral with the parking brakes engaged fully.
I don't see it.wireman said:Holding the car on the service brakes (regardless of how strongly) is foolhardy, when some errant and inattentive driver collides with the rear of your vehicle you the driver will stand still momentarily while the rest of the vehicle including its footbrake pedal will move suficiently forward to release the brakes fully......You cannae change the laws o' physics
Queing at a junction with the brake lights lit is an offence under the road vehicle lighting regulations "Causing dazzle" is the term, which also applies to fog lights not being used as they should be i.e. in real fog.
Not using the correct and safest process is responsible for a huge amount of the damage and injury which occurs in minor shunts.
Maybe holding the brake pedal to illuminate the stop lamps is a good idea whilst another vehicle is approaching to join behind you in a que but it would be good manners to extinguish the lights once you are certain that they have stopped behind you.
I always, as you may have guessed endeavour to apply the parking brake if the stop will be extended to greater than a few seconds, Yes occasionaly this delays my getaway by a fraction of a second but who cares?
In my experience never moving the hand brake except for the MOT is not clever since the linkages are all going to be cruded up and inefficient thus requiring servicing or repair and expense, not moving the gear selector because it might wear out is about the most feeble excuse for being as tight as a gnats chuff that I have ever read.
We all seem to be in possesion of good nice motor cars so perhaps we could all indulge in good nice driving.
SLinKyjoe said:here is some advice from an expert.
you may wish to read down the page a bit
http://www.telegraph.co.uk/motoring/main.jhtml?xml=/motoring/2001/02/13/emrip13.xml
http://www.telegraph.co.uk/motoring/main.jhtml?xml=/motoring/2000/12/12/emrip12.xml
http://www.iam-bristol.org.uk/articles/An Observing Guide.pdf
http://www.donpalmer.co.uk/handbook/part1.htm
http://www.ineeddrivinglessons.co.uk/latestnews.php
Yes perfectly. But when sliding rapidly from D to P they do not come on. We checked this very evening. Only if you go very slowly.Blobcat said:Are your reversing lights working?......
I haven't checked but I believe Hawk is right on the reversing lights issue. The box is electronically controlled so there is no longer a mechanical reason that it has to pass through R at all. If you flick it into D, the computer should be smart enough to recognise what you are doing and go straight to D. This would certainly explain the slight delay when selecting R as it waits mometarily to see if your staying there.Blobcat said:what about from P to D?
