How to identify Fuel injection System
Charlotte001
norwich
how do I identify my fuel injection system ?
does anyone have a schematic of it they could send plz
(please don't say Ebay )
Charlotte
As far as I can see you have CIS injection.
Most common fault for high idle goes up to 1k and down again = throtle switch
Malcolm
guydewdney
Tring, Herts
www.atct.co.uk
correct me by all means - but CIS was phased out over here well before 1984 (the year of mfr of this vehcile) - in the UK, but still availible in the states as CIS. AFAIK its KE jetronic
eg:-
CIS:-
KE
NOTE the biggest difference (well, the only real difference) is the CONTROL UNIT...
C
Charlotte001
norwich
Thanks for the pictures and info. The injection system, bare all the plastic pipes is exaclty as the picture send including the sensor box (CIS) I'm just going to do a basic test today to see if the pump is working and i'm getting fuel deivary.
Anymore info would be appreciated thanks
Charlotte
Off the top of my head I would have said KE the same as Stuart Hayes car.
I set out to check accuratly. When I feed in the car as a 126036 that has engine 117961 and 965.
using the engine number as 117963 that only comes up in car number 126044 fitted to a 500sec.
The numbers do not add up. yes the KE was used over here on the 116, the CIS ran well into 87 in some countries.
If it is KE I can let Charlotte borrow to photo copy 22 pages of service info as long as they are returned.
Maybe I can send a KE photo to identify what is on the car, or can Charlotte put a photo up
Thank you guydewdney.
Malcolm
C
Charlotte001
norwich
Update time
I believe the fuel system to be CIS mechanical the same as the 450 Series engine (117 I believe) I have an old manual of the 450, checking the fuel system it appears the same. I have also found one of the two jubilee type clips to have failed in a major way, although I cannot remove this.
Is it possible to remove the fuel distributor without removing the inlet manifold ?
Yes I would like to borrow your manual. Can the fuel system be identified from it's serial code?
Charlotte
