How to remove a front wheel stuck on hub
t15dja
West Midlands
Anyone got any suggestions on how to remove one of my front wheels that appears to be stuck on the hub please?
Having removed all the nuts, the thing won't budge. Tried thumping it, kicking it etc etc but its stuck fast!
Other side came off easy. Wheels are in good nick, recently refurbished so no corrosion.
Thanks in anticipation.
T
t15dja
West Midlands
have tried hitting the tyre with the flat side of a normal sized hammer but no joy. Also, I'm a bit worried about how hard I can hit the tyre - don't want to damage the sidewall
dave.robbo
Gloucester
2004 SLK 350 R171
Don't use a hammer!!
Use a rubber or hide mallet on the rim of the wheel.
sixpack
Renfrew Scotland
2012 w212 220
Stuck wheel
Loosen wheel nuts slightly and try rocking the car sideways, or drive slowly (carefully!) to free it.
Peter
hardtop
south of glasgow
wheels can seize on esp alloys sometimes the only option is force none of this mallet stuff just a huge hammer
colechelle
Resigned
Peter
agreed, half a turn on each bolt and a drive round the car park, soon be free!!!
rpe2
Silchester
Don't forget to put some copper slip/ grease on the hub afterwards to stop the wheel sticking again.
Richard
I often just whack the side of the tire with a long piece of 6" x 2" wood
Xtractorfan
S class
You should never hit the sidewall of a tyre with a hammer, as malcolm I tend to use the plank of wood, but some of them are a right pain.. if you're at home you could try pouring a kettle of boiling water round the wheel centre.. keep the feet well back..
rf065
Grossbritannien
You don't happen to run a hotel in Torquay and go by the name of Basil Fawlty by any chance?
Russ
Russ
Thats where I learnt to do that Russ :D:D
Bowruss
Preston, Lancashire, UK
E Class Estate 211 Avantgarde 2004 with sports option, Comand, etc.
I had the same problem with the last car I had - a VW Passat - again with alloy wheels.
I had the car up on the scissor jack with all the nuts loosened but no amount of pulling and shoving would shift the wheel. I stopped because I worried the car would come off the jack and damage the bodywork.
I had to call out VW Assistance. He - sensible man - got out his trolley jack, lifted up the car, got out his rubber dead-head mallet, whacked it twice on the inside of the wheel rim and off it came. Apparenly these mallets have a lead shot filling (or something similar) and the movement of this magnifys the power of the blow. A bit like the old sand and sock routine but don't ask me how I know this.
Anyway, he said this alloy wheel thing was a really common problem. He reckoned there's a chemical reaction between the alloy and the steel hub. He also said to make sure they coat the mating surfaces with Copaslip next time the wheels come off.
I now have a trolley jack and a rubber mallet thought it's not a dead-head...
Russ.
wireman
lancashire
Its a DEAD BLOW HAMMER. A dead head hammer is the standard issue at some major tyre shops.
I prefer the loose nuts and slow(ish) drive round the car park, until it starts to wobble and clonk should be enough, it worked on a 42 ton eight wheeler when nothing else did.
