minimouse0203
- Nov 4, 2008
There are two nobs on the instrument panel. The nob on the left resets your odometer, this is the nob we are going to use, lets call it button 1. In addition, there are two positions when you insert the key nto the ignition. The second position lights up all of the instrument lights before turning on the car, this is the position we are going to use, lets call it position 2. 1. Turn key in steering lock to position (2) 2. Within 4 seconds press button (1) twice 3. The present status for distance is displayed. Within 10 seconds turn key in steering lock to position 0 (starting position without taking the key out) 4. Press and hold button (1), while turning key in steering lock to position 2 again. The present status for distance is displayed once more. Continue to hold button (1) 5. Release button (1) when you hear a beep. You have now reset it successfully. as i say it may take a couple of attemts can i also add YOU NEEd to have all dorrs and boot and enginge closed before it will work. please get back to me if having probs?
