HP Diesel pump woes
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by mercedes13156, Dec 27, 2012.
  1. mercedes13156
    mercedes13156 Senior Member
    1,259
    209
    Dec 27, 2005
    West Lothian
    Your Mercedes:
    CLK 200 Cabrio and a Ford Kuga
    Hi there,
    I've got a W203 C220CDi and the HP fuel pump is leaking a bit. There's a smell of fuel in the cabin when I stop with the engine running. I'm not too confident that I'd be able to refurbish it myself, so I went to Euro Car Parts and they said they had one for a 270 CDi and one for an A Class diesel 170 CDi in stock and that they were effectively all the same part, despite having different part numbers. They are all exactly the same shape and specification and deliver fuel to the rail at the required rate and pressure.
    The Merc dealer told me a different story and said that I must use the one on his system or suffer the consequences and I'll have to wait until one comes from Germany after the New Year.
    My question is, could I take one for a 270 and expect it not to blow the arse out of the system? Similarly, would the one for the A170 fit the bill?
  2. curious
    curious Senior Member
    322
    85
    Nov 17, 2008
    Your Mercedes:
    Only the Vito left! OM646
    My fuel pump starting leaking on my W203 c220cdi and, after getting rediculous prices for a replacement decided to have a go myself.
    I don't know where your's is leaking but mine was from between the backing plate and the main body (bolts had come loose).
    I got a service kit froma Bosch service centre (approx £15) and replaced a few 'O' rings without having to completely dismantle it all. That was 50,000 miles ago.
    If you're capable enough to replace the pump you're capable enough to do what I did.
  3. OP
    mercedes13156
    1,259
    209
    Dec 27, 2005
    West Lothian
    Your Mercedes:
    Mine's is leaking from one of the heads. I've got a procedure from the forum, but I'm not confident that I can it. I don't have a workshop.
  4. Rockall
    Rockall Senior Member
    286
    Feb 22, 2012
    Donegal Ireland
    Your Mercedes:
    Many
    All you need is the kitchen table for a short while!!:)
    Regards
    Bill
  5. Frontstep
    Frontstep Senior Member
    7,391
    1,275
    Apr 22, 2007
    Your Mercedes:
    T210 320cdi
    Those little head bolts can be very tight, but mines done about 5,000 miles since I cheered it up with a seal kit
    I think corrosion gets into the heads, I rubbed mine flat and shiny.
  6. OP
    mercedes13156
    1,259
    209
    Dec 27, 2005
    West Lothian
    Your Mercedes:
    OK. If I go for replacing the seals, would it be wise to apply a light smear of gasket goo on the heads, or is that a really daft idea?
  7. lwbnick
    lwbnick Senior Member
    1,288
    Mar 4, 2010
    wales
    Your Mercedes:
    expedition
    Why not try a GSF and see if they have the right one in stock?
  8. OP
    mercedes13156
    1,259
    209
    Dec 27, 2005
    West Lothian
    Your Mercedes:
    If I could spend £30 refurbing it I would. I think I'll give it a go. If it doesn't work I've lost £30. if not I get to spend about £300.
  9. OP
    mercedes13156
    1,259
    209
    Dec 27, 2005
    West Lothian
    Your Mercedes:
    Going back to the original question, anyone know if the A Class 170 or the C Class 270 HP diesel pump will work properly on a C220 CDi?
  10. rpe2
    rpe2 Senior Member
    2,863
    Sep 25, 2006
    Silchester
    Your Mercedes:
    They have different MB part numbers so I'd guess they are different in some way.
    Looking at the ECP website there are different part no's also.
    Would therefore summise that they are different.
    If you asked the laddie in ECP to warrant that fitting the 'wrong' part will do no further damage, he may change his line.
    As above, refurb it for pence, or ask ECP/ GSF for the correct part.
  11. OP
    mercedes13156
    1,259
    209
    Dec 27, 2005
    West Lothian
    Your Mercedes:
    Point taken. Off to buy the refurb kit.
    Thanks to everyone who contributed!
  12. mersum1es
    mersum1es Senior Member
    1,956
    229
    Sep 25, 2010
    Finland
    Your Mercedes:
  13. OP
    mercedes13156
    1,259
    209
    Dec 27, 2005
    West Lothian
    Your Mercedes:
    Hi again,
    The seal kit didn't work. Turns out that the whole pump was goosed. The main rotor inside was worn and I've exchanged it for a fully reconditioned pump. I've put it all back together again and now it won't start. The two plastic pipes are in the right holes, (there's only one way to fit them) and the steel pipe to the rail is nice and tight.
    When I crank it over, there's air bubbles going into the pump and when it stops, the air bubbles go the other way. I've cranked it over about 30 times and nothing. It won't catch at all. There's about 2 gallons in the tank and the fuel light hasn't come on yet.
    What am I doing wrong?
  14. Silver_Star
    Silver_Star Senior Member
    2,294
    8
    Apr 20, 2009
    Rural Leicestershire near where Pork Pies and Stil
    Your Mercedes:
    W203.006, S211.208 Land Rover 90
    If it is all fitted correctly just keep turning it over and it should take once the air has been purged. It may take 30+ seconds of cranking.....however keep the cranking continuous don't stop till it takes.
  15. OP
    mercedes13156
    1,259
    209
    Dec 27, 2005
    West Lothian
    Your Mercedes:
    It won't crank for 30 seconds straight. It has an auto start function which cuts the starter after about 10 seconds, even if you hold the key on.
  16. Silver_Star
    2,294
    8
    Apr 20, 2009
    Your Mercedes:
    Do you have a vacuum extractor? may be worth trying to disconnect the fuel line that feeds the rail and try and pull diesel through.
    Hopefully an indie may be along to advise on this shortly.
  17. yorkshire1
    yorkshire1 Senior Member
    1,036
    26
    Apr 10, 2012
    East Yorks
    Your Mercedes:
    "98 S202 C250TD Manual hybrid
    easistart
    give it a whiff of easistart if its only residual air in the system the faster cranking,ll soon get it going and save your starter/battery too especially this cold weather
  18. Frontstep
    7,391
    1,275
    Apr 22, 2007
    Your Mercedes:
    T210 320cdi
    Mine did take quite a few goes to start it but not 30.
    I did fill the pump with clean diesel first and some probably stayed in whilst fitting.
    Unless something else wrong I suggest charge battery and keep cranking.
    Don't forget to rest the starter so it doesn't overheat.
  19. mersum1es
    1,956
    229
    Sep 25, 2010
    Finland
    Your Mercedes:
    Yep it would be good to know is the reason now that rail pressure is too low, or is it something else. I read the trick that if you unplug the rail pressure sensor, the ECU can't have knowledge about too low pressure and will start. Goes straight to the limp mode but starts nonetheless (works also if faulty pressure sensor. Edit: of course won't start if really cannot buid up enough pressure). Bubbles in fuel lines tells about problems in fueling, check the connectors of the shut down valve too. Again, fault codes/live data would be benefical...
  20. rpe2
    rpe2 Senior Member
    2,863
    Sep 25, 2006
    Silchester
    Your Mercedes:
    Did you smear the pipes with a kittle oil before refitting to the pump
Share This Page
