I Brighton
brighton
New Registration
A170 w169 2006 model
Please assist with my mercedes Benz a170 w169 it started to loose power while I'm driving when I want turn while I'm changing the gear it become off and I start again and drive 5 minutes I stuck again I try to start with push it doesn't start I call mechanic he is suspecteing the engine seized which is not true
SmartAmg
2011 E class coupe 350 CDI
DREAMER NO2
W124 2.6E M103 1989
brighton Wish i could help you .But it is hard to pin point the problem without inspection . Get a second opinion on the engine . Pull the plugs out and select nutral , put the service brake on , then use a spaner on the nut that holds the crank pully to turn over the engine .And if the engine turns over ,then its not seized up /
www.W140.co.uk&www.r129.co
